Pump on this pressure washer is a consumer grade axial cam pump (see photos). Is it possible to adjust pump pressure? There is a gizmo (unloader valve?) that appears adjustable, is this possible or even wise to adjust? Looking to lower pressure, not raise it.
Would reducing engine RPM be an acceptable alternative method?
Also, anyone know what the plastic hose is at the bottom of the pump? It's not the soap hose, that's above the pump. The hose in question just hangs down and goes nowhere to my knowledge.
