I'm in the midst of changing the window regulator/ actuator and had to remove the inner water proof plastic. The Acura is now 13years old and the adhesive which holds the plastic is no longer soft enough to reuse.
What do you recommend I use for this job. I'd like to get as close to origional as possible since I'm keeping this old girl till they pry me out of it.
Thanks for the help. Smoky
