adding syn to mineral
australia
hello all, could you please tell me if i will run into any problems adding a remaining quart of motul 15-50 ester oil into 2 1/2 quarts of Havoline 20w50 mineral oil next service on my harley, as i don't want to waste it and don't wish to buy any more motul. in fact, will i have any problems mixing any auto oil at all or are all modern oils compatible?
hope this isn't a dumb question, but i am a recent member and this is all new to me
they are campatable as far as the mixing is concerned, however if you really weren't satisfied with the perfomace of the motul, i'd save it for the lawnmower or the like. the havoline will serve ya great, especialy for shorter drains, and if you choose to run an analysis on the havoline, the 15-50 might sabotage the final results a bit. penz
Agree with Penz...
i always do that to my 02 suzuki GSXF
whatever i had in hand, brands, 10/40, 15/50,
20/50, dino, syn, sl, sm..... i mix them up
never had any problem, no clutch slipperage,
no oil burnt, no engine hesitation.....
altho its not a harley, just some FYI
I don't understand why you want to do that, either run one oil or the other, IMO
And mixing ester and mineral oil is not a practice I would use, unless it's been scientifically tested and formulated.
