So I just bought a 2004 Acura MDX and was planning on doing some fluid changes. This vehicle has 280,000 miles, and I want to keep it going. So here's what I'm planning on doing.
1. Replacing transmission oil with Valvoline Synthetic Multi-Vehicle ATF, which claims to meet the Honda Z1 Spec as called for in this car. Has anyone used this ATF before, and is it any good, or should I just buy some OEM Honda fluid?
2. Replacing the transfer case oil. It calls for an "SAE 90" gear oil in the manual, except from what I can tell, such a straight-90 oil does not exist and all I see are 75w-90, 80w-90, etc. Should a 75w-90 or 80w-90 synthetic work okay in the t-case?
3. The engine oil has always been Valvoline 5w-20 conventional, and I see no reason to alter this.
4. Finally, I was planning on replacing the diff oil with the Honda VTM-4 oil, which appears to have no interchanges, so that is fine.
Answers to the first two questions would be much appreciated.
