Hello everyone,
I've been already asking if low saps oils are any good for the engines where they were not specifically demanded to be used by manufacture.
The general answer I got on this forum is that since this is low saps oil, it will do a worse engine wear protection than ACEA A3/B4.
However, if I compare on lubrizol https://www.lubrizol.com/apps/relperftool/pc.html these specifications (ACEA 2012) I can see that ACEA C3 has the same engine wear protection as ACEA A3/B4 (index 6) however it outperforms A3/B4 on fuel economy, oxidation thickening and catalyser protection.
http://pasteboard.co/2gGbz30U.png
I can also see that Castrol is not selling in Europe 5w30 viscosity (which is quite popular) with ACEA A3/B4 only. Instead they sell Castrol EDGE FST 5w30 ACEA C3 here.
Does it mean that Castrol is moving away from A3/B4 towards C3? Is there any criteria why A3/B4 may be better than C3?
I read somewhere that if you live in area where fuel has high sulphar quantities A3/B4 is better, I wonder if this is true or not.
The reason I am asking is because all my cars allow ACEA A3/B4 or ACEA C3, however I choose A3/B4 thinking it will do a better engine wear protection. Now, I can see that this is not necessary the truth ...
Another thing which worry me is that if I take Valvoline SynPower oils for example, I can see that:
- ACEA A3/B4 Valvoline oil is called "Valvoline SynPower 5w30"
- ACEA C3 Valvoline oil is called "Valvoline SynPower Xtreme XL-III 5W–30"
It looks like they use the word "xtreme" with ACEA C3 which I guess means it has some better protection in extreme conditions?
Overall, I am trying to determine if I should switch to C3 oils in my next oil change ...
