Originally Posted By: kukaepe
My '07 MINI Cooper S (direct injected, turbo gas 1.6l) calls for ACEA A3/B3 Synthetic oil at intervals when the ECU recommends an oil change. First time the ECU called for an oil change was at approximately 18K miles. My habit has been to change the oil and filter in all my cars at 5K intervals. My question is if I am going to change the oil at 5K intervals is an ACEA A1/B1 oil adequate? Are the differences in the two oil ratings for those applications with extended oil change intervals? ACEA A3/B3 rated synthetics in a 5w30 weight is not easily found in the USA. Any thoughts? Thanks Mike
Mike,
I read too many answers that didn't address your question directly.
It is 'reasonable' to use an A1/B1 and reduce the OCI. The problem can be warranty if ever required. I'm thinking like you; 18K OCI on a direct-inject turbo .... NO THANKS...5K sounds prudent and cautious in early years of vehicle. I would still be inclined to look for A3 but generally much more costly so economically the OCI should be extended... If spec is 18K I would use a A3 to 9K as example.
Mike,
