AC-Delco UPF52 question
According to AC-Delco, No:
"The graph above shows that Ultraguard Gold filters nearly four gallons per minute of cold oil at a differential pressure of 10 PSID (typical bypass valve opening pressure). Compare that with the Wix Sport Truck brand, which filters only 2.3 gallons at this pressure, or the Mobil 1 filter that handles just 1.6 gallons.
With Ultraguard Gold, you ensure that a good supply of filtered oil is always going to your engine to effectively reduce wear."
I think the graph is misleading though...if your bypass valve kicks in at 8-11 p.s.i. (a common number), then the rest of the graph is pointless...no oil is being filtered.
[ October 19, 2003, 01:29 AM: Message edited by: Jelly ]
Don't know what differential they are talking about but when a bypass valve opens there should be an obvious knee in the graph line. The pressure may be system pressure rather than the differential across the filter itself, which is what opens the bypass.
The test is probably academic at best. They probably used a machine to test the filters, and used a 1218 or something like it, that doesn't have a bypass valve, just to get numbers for the test. But it does seem that the UPF's are superior in flow.
