2WD, half-ton, 59,000 miles
So I started the truck the other day, and the ABS pump started running and wouldn't quit. Brakes still worked with the pump going--I drove a couple car lengths to another parking spot and pulled the fuse. With the fuse in, the pump will even run when the key is off. I had Autozone check for codes, but their reader doesn't do ABS.
Has anybody else had this problem? I'd like to know what to expect before I take it in. Also, can a good independent shop diagnose and repair this kind of thing, or do I need to go get assaulted by the Chevy dealer?
