My 2003 Nissan Pathfinder LE auto 4 wheel Dr, the abs light came on then theh 4 wheel drive light came on and locked out my selector switch so I can not switch it into 4 wheel unless I fix the ABS wheel sensor which I checked and its opened and has to be replaced, its to cold with snow now , so if I pull the ABS relay or fuse under the hood will my 4 wheel selector work now without the abs which I'm not concerned about now until after the weather gets warmer. ? thank you Ron - [email protected]
