ABS light comes on everyday
If you can get a pin out of the ABS modulator connector you can easily see if the sensors are good. Connect a voltmeter set on AC volts to the two sensor wires for each wheel and then spin that wheel. You will get a signal that varies with the speed of the wheel. The front and backs probably don't read the same but side for side they should.
Originally Posted By: Bladecutter
The real question I have is why did you not know your car will have ABS sensors in the rear of the car?
Simply stated, I don't know much about ABS systems. The service manual provides a good explanation; I need to sit down and read it.
