Quote:
Quote:
Pardon my ignorance but what is the benefit of a thin oil?
Doesn't it shear down to where it doesn't work as intended?
They're after efficiency in the flow of oil through the engine, Tripps. With thinner oil, the lesser resistence to flow enables you to run a smaller oil pump, narrower oil passages and the parts that move through the oil (the crank and of course the oil pump mostly) have reduced energy losses vs. 30 and 40 weights. This all adds up to greater fuel economy of course, as well as more compact and efficient build of the block to begin with. In spite of a lot of old head philosophy (which states 30 and 40 protects better than 5W20), today's SM/GF4 rated 5w20 conventionals are as good as the synthetics for 3-5K OCI, and some folks run it longer than that even with great results.. Fortunately, the base oils that make up 5W20 are greatly improved, there are few, or no VIIs, and all this makes a better oil, again, for new cars built the ground up for them as well as many older cars whose manufacturers are backward-spec'ing 5W20.
There are other factors in play, but that's the gist of it.
