a tee in the heater hose to flush
Near the beach in Delaware
Years ago when you could fit one in, I would buy the little kit from Prestone, that had a tee and a garden hose adapter and a spout to flush the system. Is this still a good way to flush the system assuming I can fit it in? Or better to bring it to my friendly shop and have them do the flush?
My Suburban has a front and rear heater core, are there any tricks to making sure they both get flushed? There is a tee in both the supply and return heater lines under the hood to feed both heater cores. Unsure if there are any one way valves tn the plumbing.
I've got 'em in my '75 Dart and my '77 Chevy pickup- the Prestone tee thingies are OK in my opinion. I like to open the radiator petcock and adjust the hose flow to equal the discharge from the petcock, begin with engine cool and idling after I have the correct flow.
However, antifreeze on the ground is not environmentally-friendly and ethylene glycol is quite toxic to mammals such as dogs. Yeah, I still do it but I hose down the area real good after I'm done. Too bad I don't have some Bitrex to spray down the glycolized solution with.
Just my 0.02-
I thought about putting a tee in my bmw. However, it has a second water pump to keep the flow to the heater high while idling. Not sure how if a tee would work. Instead, I first drained the radiator (disposed the old coolant properly) and filled it with distilled water and Prestone engine cleaner. The type you drive 3 to 6 hours and then drain.
Next I drained the block and radiator and poured the old antifreeze down the sanitary sewer. its ok in my area. I then flushed out the system with distilled water. Again pouring the old coolant/water down the drain.
I then flushed it one more time with distilled water and resealed block and radiator and refilled with 50/50 Zerek G05 and distilled water. Just my experience.
The tee is fine for flushing. IMO it is not for long term though. Every one I've ever left in began to leak coolant at the screw cap. Now I insert the tee for flushing, and replace it with the proper size brass hose barb when done.
