A/C performance woes...
Up State NY
Well warm weather is upon us in upstate NY. My 300's ac performance.. well.. sucks to say the least. My buddy evacuated the system, pulled a vacuum for an hour and recharged to 1 lbs 8.5 oz, which is just a hair under the 1.628? pounds of R-134 it takes. When it was in the 60's and 70's it worked great. There were a few times going down the road you'd get a blast of not so cool air then it would go back to ice cubes. Fast forward today I was on my way home from work and it was barely cool. Ambient temp was around 92F. After driving at 60 for about 30 minutes it would cool down but as soon as I stop it would blow warm. Start driving and it would cool down again. That was very annoying for a 3 hour ride.
Once I got home I let it idle for 10 mins on max ac. It was barely cool in the car. The fans are working, both are churning on low and kicking up on high. The low side is COLD and the high side is HOT like it should be. I threw my gauges on it, well just the high side. I could NOT get the service cap off the low side, my buddy tightened it very tight and it's not very easily accessible. The high side read 250 psi at idle or 2000 rpm. I drove my wifes Avenger around and her ac is ice cubes regardless of speed. When it cooled off tonight it worked find at speed but was still warm at idle.
What could the cause of this be? I don't think the condenser is faulty because the suction line is very cold and the discharge side is hot. Do you thing that the expansion valve is starting to go out? I might add the compressor isn't cycling, it's on all the time.
Your receiver/drier may be failing internally and clogging the expansion valve. It seems to be standard policy to replace it when doing a full recharge.
Could very possibly be the condenser. The internal passages on modern condensers is astonishingly small. They clog very easily, and many manufacturers recommend replacement.
How much junk is clinging to your condenser and your radiator? It would be wise to spray the back of the radiator and condenser with a garden hose.
Does the blend door move the way it should? Sometimes it will stick in a position where it will let both air from the heater and from the evaporator and lower the effectiveness of the A/C. If there is a sensor in the ventilation ducts, it would interpret the air as not being cold enough to cycle the compressor off, explaining the lack of compressor cycling.
Does your car have all electric fans, or does it have one that is clutch operated? Sometimes the clutch will work okay at idle, but fail to keep ur as RPMs rise.
I hope it is the expansion valve and drier, it's very easy to get to both and they're cheap.
While the condenser can be had very cheap, you have to take the front bumper off to replace it. Not fun, I hope it's not the condenser.
Visibly it looks clean, may be worth taking the hose to some day. The fans (which are electric and functioning normally to answer your last question) are easy to remove. An electrical connection and 4 bolts. Blend doors are fine, no noises and I can get full heat and ac anytime.
I had a Jeep Cherokee about 9 years ago where the AC would work for about 10 minutes and then warm air. It didn't leak and the refrigerant charge was full. The Condenser was beat up from many many highway miles. I replaced the condenser, receiver / drier and the expansion valve and afterwards you could hang meat in that thing.
You have a restriction somewhere in your system.
Toss the drier/accumulator, condenser, and expansion valve.
Flush the system. You'll be amazed at what comes out.
Modern condensers are un-flushable. Stop beating around the bush and toss the old girl.
When it gets good and warm I'm going to get both sides measured. The low side service port is between the engine and shock tower facing the ground...
That means the refrigeration loop is WORKING. The air leaving the evaporator would also be approximately that cold. Something is wrong under the dash causing it to reheat the air when it shouldn't because you have the controls set for full cold.
I had a truck once that would do the same thing. It turned out to be the compressor clutch. It was worn to the point that when I stopped it would disengage but accelerating made it catch again. This was on a rear wheel drive truck though but still something to look into.
can you bypass the itnernal heater and loop the coolant in the engine bay? if the AC works as it should then, you know you have to look inside the cabin... or, disable the mixing flap if you can reach it, so there's no way hot air can be mixed in.
I was thinking compressor clutch slipping as a maybe, but then again 2007 isn't that old really.
If you do lots of HWY driving ("3 hr ride"), you might benefit from a thorough external condensor cleaning. Is it clogged with bugs? Cheap, sudsy ammonia works great at dissolving dried bugs. Spray on a 50/50 mix and let it work about 8 min. as it needs to rehydrate them first before disassembling the proteins. Flush with water and repeat.
When you update your gauge readings, we also need the ambient & dash vent temps.
I was going to do that today but it ended up raining before we got home from town. It's too cool to reproduce the symptoms. I live 3 hours north of Syracuse, it's not a bad drive in good weather.
It's very possible it's clogged with bugs, what do you mean sudsy ammonia?
Down here it's labeled that. It's yellow in color. I think it has a detergent mixed in, though ammonia itself is an excellent detergent being quite alkaline.
Because it actually dissolves dried bugs, it's great for washing the condenser. Also great for removing them from your front end, license plate, windshield, side mirrors, etc.
We get swarms of love bugs & butterflies during certain seasons and my white car will be covered in dried bugs after a road trip. Ammonia is a god-send for removing them without hard scrubbing.
I'll have to look through the stores and see. I did check the blend doors. They're both functioning, the doors are moving through their full range of motion. The condenser and evaporator are obviously working. It's makes me think the expansion valve is getting lazy.
If the TXV sticks closed, the low side line will get warm. Also there will be an abnormally low low side pressure. Both easy to check.
Could be. Gently tapping it with a hammer might free it up.
