A/C and MPG
MIchigan
I decided the other day I was going to check my Mileage on the way to work with the A/C OFF. And compare it to the Mileage with the A/C ON... on my way home. BTW it's 35 miles to work. Here's what I got.
To work with the A/C off I got 22 MPG
To home with the A/C on I got 20.5 MPG
With the long commute...I was always trying to save money on gas but after this test maybe I'll go ahead and just use the A/C. Thoughts?
Windows open = more drag. I would never turn off A/C even if I could save 1 MPG.
Is it uphill in one direction and downhill in the other?
Into the wind going one way, against the wind the other way.
Just 2 of many factors.
Originally Posted By: Warstud
Originally Posted By: gathermewool
Not enough info
What's Missing?
More than two dissimilar data points. Wind, terrain, congestion, etc all change going vs coming.
Even if my mpg dropped 10 mpg I wouldn't stop using A/C. It's 112 outside and I have black leather seats. Not happening.
Some of us deem it unprofessional to show up in a sweat soaked dress shirt and tie for a mile and a half per gallon. If it's so troubling, buy a smaller car.
Right...2 many factors that would never be equal. Maybe a weeks worth of data would be more accurate.
Link I posted shows the power loss that the ancillaries use, and it's not insubstantial.
If if it only takes 20-30hp to motor, the losses are quite large.
If you drive about 5 MPH slower you can gain more than 1-2 MPG.
If the driving speed is below 45-50 MPH then A/C off and window down when temperature is no higher than 70-75F, otherwise A/C on to serve you.
I'm glad my DD takes a very small hit when using the AC. No matter, if it took a good hit in mpg, I'll still use it - I'd rather pay the extra for comfort than feel uncomfortable - I do the same for the house, I keep it cool day & night indoors all summer.
