After 165,000, the left inner tie rod end has worn. After looking over the shop manual it implies that the rack should be removed to replace the ends. I went at it today thinking it can be done without removing the rack assembly but now I'm not so sure.
There's plenty of clearance, and if I use two crowfoot wrenches I can both hold the rack and turn the rod end. The problem is that after you put the new end on, you have to bend/fold down a lock washer to keep the rod end from unscrewing. I see no way to properly bend down that washer with the rack in the car.
Removing the rack isn't that big of a deal, it's just all the spilled fluid that will be the biggest hassle (that and disconnecting the intermediate steering shaft). That whole job looks like an hour or so each way plus another hour to refill and bleed the power steering system.
Anyway, has anyone ever replaced inner tie rod ends on a Sienna? A Camry is probably about the same. If so, did you take the rack out of the car?
The one good thing about removing the rack is that you could do a proper job of torquing the rod end AND flattening down the lock washer.
