While driving down the road & attempt to give it more throttle (ie: to pass another vehicle) it will "buck" once it tacs at 3k. This will do this each time.
That problem became more erratic yesterday afternoon coming home. Acting as it was losing power & would buck more.
We replaced the motor last year around time, because of blowing the skirting off of #3 piston.
Have had no issues with this motor until approx 7 months ago when it would buck at 3k on the tach.
Codes that were pulled yesterday
P0 152
141
132
161
138
158
1494. P1494 is a leak detection pump, SW or mechanical fault. Leak detection pump switch does not respond to input.
All others were upstream/downstream O2 sensors high/low circuit or temp.
I have checked all vac lines & came across 1 that goes from the intake manifold to a small electric pump located underneath the air cleaner housing & right directly behind left headlight. The 90* elbows are brittle & started to fall apart in my hands while trying to remove them.
The motor may run good for a bit, however shut it off & turn it back on, it will run extremely rough as if it is missing.
Checked the fuel pressure which was around 52 psi, well in range.
I am at a complete loss with this, any ideas, input or help would be greatly appreciated
