I have a 98 Expedition 5.4 4x4 with a 4R100 transmission. Over 200k miles on transmission.
Recently the truck was stalling while shifting in reverse and also shifting to low gear. The truck drops in RPMS and sometimes stays running and sometimes stalls.
The transmission fluid was low, no reading on the dipstick. I added a 1/2 quart that I had on hand and it did not do it.
2 days later it is starting to show same symptoms again, I still need to add more fluid to bring the level up where it belongs.
I don't see any obvious leaks around pan gasket or rear seals on transmission and no stains in my driveway.
My question is, where could my fluid be going? Other areas to check for leaks?
