98 buick lesabre,how many subframe bushings does it have?
stamford, CT
Hi all! 98 Buick lesabre.looking to replace my subframe bushings. I know theirs 4,but I see kits with 6.and a YouTube guy, 97 lesabre,has 6 bushings.
Is it 4 or 6?
My front ones are practically gone.
Rockauto has a kit for 4.
Ebay,cared have a few for 6 .I'm going by what rockauto lists. So I knew Their would be 4. But 6?
Is it 4 or 6?
I used to own a Buick Century, similar but smaller, go to Any parts store or Internet site, if they say 6 then buy 6 or buy what you feel comfortable replacing now !!
Ok 6thanks!
Too bad they don't sell 6 pack kits.i only see 4 packs,and then individual bushings.
Ah ok thanks!
The part number is 924-043. Dorman.
One ebay kit is $385 ,$12.95 s+h.6 piece.
Another is $400 free shipping..the others are 4 piece or one piece.more expensive that way
I BELIEVE (and could be wrong) that the H body used 2 front and 4 rear subframe mounting points. The W body used 4. Your LeSabre is an H body, so it should have 6.
But....ok
924-043 are the front bushings.i.need 4 of those.
For the rear,I need 2 bushings. What part numbers would those be?the rear!?
its 6 and the frames like to rot out around the bushings where the upper bushing passes through the frame. Repair of that requires welding in a patch panel.
Agree with him.. Definitely give all the mounting points a good looking over. I recently acquired my son's 97 andshortly after he bought it, the subframe pulled through the rear bushings.. Bandaged it up and limped to the shop and did some welding/fab and put it back on the road.
The 4 front bushings,are 924-043.
Are the 2 rear bushings the same part number?if not,what part number Ami looking for?
$28.26 and free shipping. Your total bill should be $113.04 plus your labor. https://www.ebay.com/itm/224178547763?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649#vi-desc-maincntr Part number is 924-044. Charts say it fits 97-05 Lesabre. I own 4 roadworthy Lesabres; there are 4 body mounts, they go in front. Rear of the car is coil springs and different mounting.
Thanks! The eBay website,has a part fit checker.shows it will not fit a 98 lesabre.nor the 98 leaves is listed.sure part 924-044 will fit?
I do know, 924-043 will.
