Originally Posted By: Juelz
Originally Posted By: 901Memphis
You will lose the advantage of extending drains , which is where synthetics shine, but you can still do some pretty crazy miles on a Honda engine with API SN conventional.
If you want to stick with synthetic you could go to WM and get Supertech synthetic or QSUD which is cheaper than most others and still great products.
PYB, M5k, Motorcraft, all cheaper choices too.
thanks and since the synthetics have the extended drain benefit are they really more expensive or does it work out because instead of changing at 3000 you change at 7500 miles?
The answer is, "It depends." Some synthetics are toast by 7500 miles in normal service; others go well over 10,000. Right now, the best everyday value for synthetic looks to be Mobil1 (and AFE, and M1HM) at Wal-Mart - less than $23 for the 5-quart jug. QSUD had a price increase about the same time, and is just under $22.
3000 miles on conventional isn't necessary unless you do lots of short trips or hoon the car to within an inch of its life. Any API SN conventional will easily do 5000+ in that application with a properly functioning engine and "normal service" driving conditions.
If you want to save money on your maintenance, check the sale/promotion sub-forum here. The FAR (free after rebate) days look to be behind us, but AAP has a solid deal in August on 5 quarts of Havoline synthetic and a PureOne filter.
