Hi folks, customer vehicle i am working on, having a problem with abnormal high side pressures
the ambient temp was 85 degrees and the high side pressure was 325 psi and the low side was perfect at 30, i believe there is a restriction somewhere in the high side of the a/c system, my belief is since the car has low mileage and only 80 thousand miles , and the high side pressure port cap was missing.
I believe the prior owner to my client may have filled the system with stop leak slop through the high side fitting somehow as there is nasty goo there. I have a a/c flush gun, manifold gauge set & vaccum pump, so i will go to my buddy's shop and recover the air con system. I really don't want to dig my heels into something with stop leak, but it's a dear friends car and i want to take care of her
I am thinking one of two things here, either the filter/drier has ruptured or the expansion valve is sticking. Any way to findout if there is gobs of stop leak in the system the easy way before i go taking stuff apart to be sure i'm not getting myself into a headache project.
I look forward to everyone's insight on this situation, thanks bitogers!
