96 Northstar recommendations?
Chicago, IL
My 96 Seville has the 4.6 Cadillac Northstar and I've run it on mostly Mobil 1 10w30 and either PureONE, Bosch, or AC-Delco filters. It's at 96,xxx miles now. I probably only put 8-10k miles/year on it these days. When I didn't use Mobil 1, I used Pennzoil or Valvoline conventional 10w30s. Well, I've come to the conclusion that synthetics are not worth the price, and I'd like to use 5w30 for the cold winter months here in Chicago since I have to park outside all day. I typically follow the advice of the Oil Life Monitor in the car, which usually gets me between 6000 and 7500 mile OCIs. I have a stock of 2 Mobil 1 filters and 10 qts. of Mobil 1 10w30. So the question now is, do I use a 5w30 conventional for the winter and then just use up my Mobil 1 stock next year, or would the Mobil 1 10w30 have better cold start protection than a 5w30 conventional?
I understand that Havoline, Pennzoil, Motorcraft, and Trop Artic are good dino motor oils. What about Valvoline, QS, Castrol, and Mobil? Which 5w30 conventional should I use for the winter months if the Mobil 1 10w30 should be saved for next summer? Beyond that, when my Mobil 1 10w30 stock is gone, which conventional 10w30 would work best for my car?
As a little background info, the N* engines seem to have a tendency to burn a little oil. I regularly give the car healthy doses of wide open throttle to help clear up the ring lands and blow out the carbon, but it still burns up the same amount of oil. The engine holds 7.5 qts. with a new filter, but I usually put 7 in it and refill when it's about 1 to 1.5 qts. low. So, over the course of a 6-7.5k OCI, I probably put 2 or 3 qts. of top-up oil in it. Keeps the additives fresh, I suppose.
It's my daily driver and I only have a 5-10 minute commute every day, so it doesn't get up to full temp very often. My goal is to maintain the car properly, and to do that as inexpensively as possible from now on.
Many thank yous in advance for any advice and guidance you can provide.
Personally I would use the Mobil 1 10w30 in the winter and continue to use it until I depleted my stock. Because you have the Mobil 1 on hand. Then when you deplete your stock, why not look at the 0W30 Castrol (GC)? I know the problems with the Northstar engines and the heavier 30W may help on consumption.
To clean your ring packs I would start looking at FP for the fuel. One ounce per 5 gallons of fuel.
JMO
I almost forgot, why not run 5W40 year around in your engine after you use up the Mobil 1. Rotella, Schaeffers are two good oils for year around use in the 5w40 weight.
I agree with 59 Vetteman that is great advise. Rotella is good for the Money. From what I heard is that GC is just great period I will give it a try once my warrenty is up. Also if you dont want the trouble of internet shopping you can try two bottles of chevron with techron then one bottle per year should be good.
Vetteman is on target. I had a STS w/ the NorthStar engine (I loved that car btw) and if I still owned it, I'd run Rotella 5w40 in it. These engines put out some good HP and they do consume oil. Rotella offers good protection at a reasonable price IMO.
Many thanks for the recommendations fellas... So it looks like the 5W-40 Rotella is only available as a synthetic. Maybe I'm just missing something on the web site. I haven't looked for Schaeffer's yet but I will. Looks like this weekend I'll be dumping in 7 qts. of the last 10 remaining qts. of Mobil 1 10w30. Any other thoughts on this topic?
One more thought: Valvoline has a product called Premium Blue Extreme, which is a synthetic 5W-40 intended for diesels. It looks very similar in specs to the Rotella/Delo/Delvac products and I wonder if anyone has used this stuff in a Northstar yet.
I have not read on here anyone using Premium Blue in a NorthStar engine, but I would think you'd see similar results to that of the Rotella T if it were run in your car.
