Ever since I purchased my car back in January i've been fighting an endless battle with mysterious under-the-hood noises in my '95 Integra. The best way to explain it is it seems like I have two separate problems at the same time. I hear a whine/brushing noise from the accessory belt area, and my air conditioning isn't working so i'm thinking those two might be correlated. I had the alternator tested by 3 separate places thinking that's what it was, but they all said it was fine, along with the belt. Also, when the engine's cold after sitting for a while, I'm getting an engine knock type sound. I thought it was the valves so I had them adjusted by the dealership who also said that they were noisy and out of spec. I thought that it would be fine after I brought it home, but they called me and told me that my timing belt was original (at 123k) and was on the verge of snapping. I had the receipt from the original owner (a little old lady) that it was done at 72k and told them this, and they swore up and down that it was original, loose, worn, and needed replacing. So they replaced the belt, tensioner, water pump, coolant, and did a valve adjustment. I thought great, my noise will finally be gone, but it was still there. Still whining/brushing and making a slight knock until the car warms up. When it warms up, it still makes the whining and brushing noise but the knock seems to go away. I'm not sure what I should try tackling first. The engine was always taken care of and I don't see how it could be knocking. I was thinking that perhaps it was something with the transmission, as I heard that those can make knocking/brushing/whining noises with some sort of internal bearings. It's an automatic, though, so i'm not sure if that's still applicable. The dealership isn't much help and says they can't find anything excessive but I can tell when something doesn't sound right. I'm thinking of changing the oil filter and seeing if that would make any difference with the cold knocking. It's currently a SuperTech filter but I happen to remember it making noises with the other two different filters i've used too (Napa Gold, Valvoline). I'm currently running Valvoline 5W30 and standard 87 Octane gas w/FP3000. The car isn't a GS-R so it doesn't require premium 93 gas. Any thoughts, or possibilities anyone thinks I should check? Perhaps the dealer did a poor job on the belt/valve adjustment?
