94 Suburban with 350 is leaking oil. It's running down and dripping off the oil filter. Is this the rear main seal or is there an oil filter assembly seal or O-ring that could be causing the problem?
Ihave a 94 with 73,000 miles on it and was just under it doing the oil and greasing and noticed the oil line to the radiator is leaking some.But yes if you have the factory engine oil cooler youhave two hoses above the filter and think a O ring between the filter adapter?
