A coworker of mines is having trouble with his civic. Its a 93 vtec, automatic model with 150k. It starts and moves pretty decent.
His problem is when it isn't warmed up, it would backfire at RPM above 2.5k randomly. Really nasty poping noises and somewhat chunging. Its a lot better once warmed up.
Common sense was to start with a simple tuneup. He told me he did the cap and rotor a while back ago but he moved the distributor, so i think he screwed up the timing hence why the backfire on colder engine.
He has done air filter, cap, rotor and now plugs and wires. Will be doing a fuel filter shortly and i'll help me check out the ign-timing.
I never found those honda connectors to disable ECU from adjusting timing. Everyone says its easy and in the pass side floor. All i ever found was the blower motor.
