I've never said that Rotella T Synthetic and Helix Ultra are the same oil. What I HAVE said repeatedly is that they are based on the same base oil, Shell's XHVI. In fact, the Rotella Syn actually has more XHVI in the base oil blend than the 5w40 Helix Ultra sold in drum lots in the US for Ferrari dealers and import shops. However, a quick look at www.shell-helix.de will show you that Shell has already moved to 0w40 in Europe, with 0w30 and 5w30 grades manufactured specifically to meet certain car makers' requirements.quote:
Originally posted by metroplex:
Are u sure the US Shell Rotella T Synth is the SAME as the Euro Helix Ultra?
So far I've heard otherwise.
Also, how much more rigorous is the testing for API SL certification vs. ILSAC GF-3 certification? I know GF-3 is targeted at gas engines ... but the Rot T synth is only API SL. It's most likely good enough for all engines. I'd like to see some virgin oil tests as well as 3k and 7k tests.
Why would the (harder) copper washer "form fit" better than the nylon composite one that's on there now?quote:
Originally posted by Terry:
FOr your leak locate a copper washer of appropriate size and torque it down to stop the seepage. The copper will form fit even with a "little " more torq and seal your leak.
I checked for burrs and made sure the whole was cleaned out. And I also made sure that the bolt seated squarely.quote:
Originally posted by OneQuartLow:
Boo. How much over did you have to go? Terry's right, check for burrs. They'll round down and deform the seal surface. Check the washer for compression angles or cuts.
Self-tapping bolts don't make high tolerance threads and they often don't seat squarely. Not knowing how much meat remains, I'd worry about losing the threads entirely while torquing for a seal. As you increase torque you'll be deforming the aluminum threads outward into the washer which could further aggravate the leak if the new threads aren't straight.
From what I understand, the higher ash levels are merely indicative of the extra additives needed for heavy duty diesel and gasoline engine use.quote:
Originally posted by Cressida:
I looked at the Rotela T this weekend but elected to pass for now. I noted most oil's designed for gasoline engines have ash b/t 0 and up to about 0.9 whereas this Shell has ash at 1.3. (Like most diesel oil's)
Since I've never fully understood why the non diesel oils avoid using the higher ash levels I'm going to assume they have no benefit in a gasoline engine. I'll look forward to some of your analysis.
No. The recommended weight for the 3.5 High Output V6 in the 300M is 10w30, which is the weight of the Mobil 1 I used. The Rotella T Syn only comes in 5w40.quote:
Originally posted by MolaKule:
Edit: Will you be using the same viscosity oil (or range) as was used with Mobil 1?
I certainly haven't seen all oil drain plugs, but I've never seen one with a tapered pipe thread. All the ones I've seen have been a straight thread with square shoulder and a gasket (fiber, or copper, or aluminum, or nylon).quote:
Originally posted by Jay:
Don't oil drain plugs have a different type thread than regular SAE fine and course? I thought they were pipe thread.
My VDO temp sender drain plug replacement is tapered thread.quote:
Ken
Since I've had to use an oversize self-tapping plug because the pan threads were stripped, this rules out using any drain valves because they only come in standard thread sizes. (But I'm not a big fan of drain valves anyway.)quote:
Originally posted by Spector:
Why not go with a drain valve (assuming you can get it in with no seepage) and solve your plug leaks forever?
