It was pinned - but apparently, it is easy to mistake where the pin goes - so, the pin didn't stop the gear retraction.
There are technical/troubleshooting reasons to put the gear handle up with the airplane on the ground.I understand the purpose of the pin but in this case does that mean someone accidentally retracted the gear or did it collapse for other reasons? Sorry, I don't know much about plane landing gear.
Thank you, makes sense.There are technical/troubleshooting reasons to put the gear handle up with the airplane on the ground.
During those operations, the landing gear is "pinned" so that the landing gear actuators cannot move, even with hydraulic pressure applied.
But if the gear is not pinned correctly, then, well, it can move under hydraulic pressure - and this is the result.
Did the Boeing aircraft make a "boinnng" sound when it collapsed?
I'll see myself out now.
