75w-85 , I can't find it !
ottawa
Hey Oil People
I have an 05 Altima, 5 speed and I am going to be changing the transmission fluid.
The Manual specs a 75w-85 gear oil GL-4
I can only find a 75w-90 GL-5 gear oil,
Can this be used in my altima's transmission,
or should I only use the nissan oil ???
thanks
nick
DO NOT USE GL-5 ONLY GEAR OIL. If you are concerned about your power train warranty, get the Nissan fluid, which is over priced and nothing worth raving about.
As of February 03 (TSB NTB03-015), Nissan began specifying 75W85 in their manuals as a bandaid fix for their notchy linkages/synchros. Prior to that, the factory fills were 75W90 GL-4 gear oils.
Amsoil and Redline make 75W90 GL-4 syn gear oils. Both improved the notchiness in my 5 speed, but did not totally eliminate it. Of the two, I prefer Amsoil (MTG). You can also find 75W90 GL-4/5 combos, but I personally am not sold on them.
"Or, contact Specialty Formulations for their excellent manaul transmission oil."
I use their MTL-P which is a GL4/5 75W-85. Terrific stuff.
75W-85 is easy to find on-line, just hard to find locally outside of the stealership.
--- Bror Jace
Castrol Syntorque GL4 synthetic is available at Dodge dealers as a fill for the 5 spd transmissions in their trucks, or from Standard Transmission, both hitting close to $15 a qt.
"Heck, I paid less than half that last month for Amsoil MTG."
My 5 spd shifts just fine, two fingers and a thumb sliding quietly and easily thru the gears.
Stealers' $15/qt!!! Might as well get SF or other boutique gear oils. Heck, I paid less than half that last month for Amsoil MTG.
Even though it is safe to use the 75w90(since that is what Nissan has used for years), reread ccs2k1 reply. It depends on your transmission shift feel and that cold northern weather. I'd stick with a 75w85 fluid.
SF is the only aftermarket 75w85 available.
The dealers(whether Nissan/Hyundai/GM/Dodge) also have their equivalent 75w85 fluids.
Another option is to mix your own.
Using Redline, MTL + MT90 can be mixed.
Or try an Amsoil MTG & MTF mixture.
