gathermewool
Site Donor 2025
I didn't remember a lot of what I'd previously learned about charging LA batteries -- ever since getting a "smart" charger -- so I had to refresh my memory (e.g., from Battery University, etc.). I still unclear on a few things.
INFO:
1. Battery: 6VDC, sealed lead-acid (SLA); I believe these are typically 8Ah or around there
2. PS: Penovo 30VDC/5A
-----can be currenty (voltage) controlling (i.e., maintain constant, set current (voltage))
3. Voltage Chosen: 2.35VDC/cell = 7.05VDC charge voltage
-----Seems like a good voltage for a small SLA battery
-----0.337A: corresponding current, with the PS hooked up, controlled to 7.09VDC (close enough to 7.05VDC)
4. Current Limit: 1/10C
-----I'm not sure how to control current for the first phase of charging
-----8Ah * 0.10 = 0.8A (800mA) seems way too high for such a small battery
-----I definitely wanted to check in with you guys before raising > 0.337A (337mA)
PS Setting (Pending BITOG Review):
Current-Control-Mode: Set to 0.337A
-----This corresponds with an intial voltage of 7.05VDC (2.35VDC/cell)
Battery University:
Battery University lists suggested limits while charging using a PS, but doesn't mention whether to control by amperage or voltage, though this may be implied in how the charging phases work (i.e., phase 1 is constant current).
Question:
So, how do I set my initial current for phase 1?
What is the ideal way to charge in each phase, using a PS?
INFO:
Battery University:
Question:
