- Joined
- Nov 29, 2009
- Messages
- 7,268
So on my dodge ram truck, anytime the trans temp gets above 150 degrees it typically goes into limp mode where it where shift out of 1st gear until I hit 20mph and then it skips to 4th and then I can get up to 45-50mph but the torque converter doesn't lock up which makes the temp go up very quickly. Anyone know why? If it's going to do it typically it will be when I slow down to about 20mph then get back on the throttle and it downshifts back into what I believe is 4th gear then it won't lock up or shift any higher after that. It's also a rough shift into 4th when it happens. The last couple years this was something that would happen maybe once a year now this has happened numerous times this year and I have to pull over and restart the truck to get it to go back to normal, but it will typically happen again if the trans is above 150 degrees. The truck has 160,000 miles of city driving. I've heard it's a worn SSV bore in the valve body if i'm saying that right. Apparantly the 07 models didn't have an anodized coating and wore out quickly. Although I don't think I can complain about 160,000 miles of city driving. I've also heard it could just be an electrical connection. Opinions?
