Hi guys. This is my first time posting,
I sent an oil sample to Blackstone. Everything turned out fine, except for 6% fuel dillution. I wanted to know what could be causing this, so I called Blackstone.
Since my car's ECU is upgraded, they said the fuel mappings might be programmed incorrectly. So I called Revo and they said they were certain that was not correct.
I called the dealership and their service advisor told be to call VW of America customer service...really? I'm under warranty but I don't know were to start...should I replace fuel pump, filter, injectors? Where could I start the process of elimination... Also, I had carbon build-up (cylinder misfire) before so I may be symptom of ongoing fuel problem. It seems like dealership doesn't really want to do any preventative maintenance, rather just wait until something goes wrong. What do you suggest I do?
Thanks for your help!
