I'm going to borrow your post ;
Quote:
" Familly member " has the 2006 2.4 CR-V. It has had ( in order ) factory fill, Pennzoil Platinum 5w20 and QS4X4TRUCK 5W20 ( syn ) . It was the quietest on factory fill, ( Yep by far ) Mine doesn't use a drop of oil over 5k.
Somewhat paradoxically quietier with the QS than the PP .
Perhaps double paradoxically ran out almost equally well from the drivers seat with factory fill (0014 -5K ) AND the QS ( 9500 - 10650 ). Filter probably not a factor was drained for 30 minutes warm and reinstalled .Did our usual " plus one drain " for almost exactly 1 extra quart .
The PP was slightly noisier upon change ( warm ) and substantially so by day three .
Stabilised after that , then later , and very gradually became yet a little noiser still in some circumstances and slightly quieter in others .
After surveying 12 CRVs ( 2004 -2006 ) and 6 other 2.4S pulled it out early .
Also worth noting ,the vehicle did appear to start slightly quicker . This was also first observed almost immediately after change .
Upon the second change from the PP to the QS improvement was noticeable just as quickly .
No recommendation - or explanation here , just observation .
Next oil change uncertain - we shall see .
