5w20 Oils Fail to Meet Extended Drain Specs
Quote:
Actually for consumers who practice extended drain intervals while under a new car warranty a 5w20 oil may not provide adequate protection for a 10,000 mile severe service drain interval or a 20,000 mile normal service drain interval (this works out to be a 15,000 mile average). Alternative oils such as Amsoil 0w30 Or Mobil 1 0w40 or Mobil 1 Extended Performance 5w30 would be better choices although the fuel economy would not be as good. Also I am not saying that it would be impossible to develop an extended drain 5w20 oil it is just that such an oil does not yet exist. Oils meeting the ACEA A3 or A5 specification in the addition to a documented lube oil analysis program should be adequate to maintain warranty protection. With current 5w20 engine oils warranty coverage may be compromised under extended drain intervals.
Horse turds Keep diggin baby! You might be the first to get to China
OEM's that do business in Europe typically specify a ACEA A5 motor oil that is capable of a 10,000 to 20,000 mile oil change. A 5000 mile severe service drain interval is way too conservative considering todays extended drain synthetic lubricants.
It seems that Valvoline 5w20 synthetic does in fact meet the
ACEA A5 extended drain specification but does not meet the BMW Long Life oil specification which requires a 0w40 or a 5w40 engine oil.
That's like saying, yes, the sky is blue. If BMW LL spec require minimum 3.5 cP, then duh, 5w-20 won't meet it!!! Does that mean 5w-20s can't do 10,000 mile drains like you said they can't??? NOPE.
Do any European manufacturers, specifically BMW, spec 5w-20? NOPE.
SO WHAT"S YOUR POINT???
The word "fail" typically is used when something is specifically tested and doesn't pass, ie actually fails. Any given 5W-20 meets the claimed specifications and I can think of no examples of 5W-20 motor failing any mfr. claimed spec.
Extended drains is an extremely vague term. It could mean 4K or it could mean 40K miles.
Since your header consists on misnomers and misleading words, I can only conclude you are either ignorant or a troll. Which is it?
BTW I have seen examples of 5W-20 going 10-12K with no issue.
