5w20 + 10w40 = 7.5w30 ?
Chicago Burbs
During December's $1/qt AutoZone sale last month I was able to buy some quarts of Valvoline MaxLife Synthetic Blend.
My truck calls for 5w30 (or 10w30).
If I mix 3 quarts 5w20 and 3 quarts 10w40, I get 6 quarts of 7.5w30, right?
I tried using a viscosity calculator online, but my iPad is too dumb for it.
Thanks
There is no such thing as 7.5w, so what you get is probably a 10w.
I can run whats recommended, and I have been.
But on my shelf in my garage is 5w20 and 10w40.
I just wanted to use what I had.
Your blend will work just fine. Actual results are a little unpredictable, calculator or not, but you'll likely get the perfomance of a 10w30 out of that.
Your blend certainly won't be overly thick with a full 50% 5w20 in there but I wouldn't expect stellar cold start performance in very cold weather (zero or colder).
That's what I thought.
My Napa Gold Filters bought on sale will arrive after March 6.
OCI is right about then too.
And by March, Chicago temps are generally above 0.
I say blend away and let us know what happens. Frankenblends are cool. I do it all the time with the orphan bottles of oil on my shelf but mostly with 5w20 and 5w30.
Never an issue.
50/50 blend of Valvoline MaxLife 5w20 and 10w40 gives 11.37 cSt at 100C. Definitely a 30-weight. Like others have said, cold flow characteristics probably of a 10W. You're mixing the same brand of oil, so there shouldn't be any problem.
Do It.
