I've an '05 Malibu Classic.
I've been reading about how this transmission has a check bolt instead of a dipstick. Also, it has been said that removing this check bolt when the engine is not running will allow 3-4 quarts of fluid to drain out of the transmission. Seeing as how this bolt is adjacent to the oil pan plug, I thought this would be a great way to do partial transmission fluid changes every OCI!
I tried it this weekend. With the front end up on Rhino Ramps, exactly 1 quart of fluid drained out of the transmission check plug.
My question to any in the know - before I go through the elaborate process of lifting up the entire car and checking while the engine is running - Is this fluid quantity correct?
Should more fluid have drained off or no?
I'm very curious to hear from someone else who has tried this.
Thanks!
Thanks!
