Why would a 4l60e whine in neutral but not in park, I've noticed it before, but the other day I was sitting in the drive thru and put my car down into neutral and I thought I was hearing beeping in the distance like a truck backing up but I realized that it was my car doing it in neutral, but it doesn't make the noise in any other gear, also the transmission seems to vibrated helaciously when it's cold and idling in drive or reverse with the brake applied so the transmission may have some problems, although there may have been a misfire because RockAuto sent me an heat range 6 NGK plug when it should have been a 5, that I swapped out for the correct plug today, I'll have to wait for it to get down to 34 degrees tonight and see if the cold vibration is still there. also the pump seems to make whining noises, and there's a noticeable noise, I wouldn't exactly describe it as a whine but it's like you hear the pressure building for the 1-2 shift and on other occasions I hear the pump whine sometimes especially around 35-40mph, I'm not sure if I'm hearing it in association with the 3-4 upshift or when the lockup clutch is being applied.
