Well, wish me luck.
I picked up a 2000 OBS Tahoe this past spring. Finally got around to the trans service today. Since I discovered "American Axle" was printed on the rear diff gasket when I did that service earlier; I think it's a fair assumption the trans has never been done, as well.
Dropped the pan, replaced the filter. Added 4 quarts of older DexIII I have on the shelf, let it co-mingle with the remaining fluid. Set up for passive exchange...
11 quarts of SuperTech DexVI, 3/8" plastic barbed fitting of the wrong thread, and a length of vinyl hose. Disconnect the top cooling line, half-assed screw in the fitting & slip on the hose.
I pumped out a couple quarts at a time, then replaced with fresh fluid. Process went well, and I think I got most of the old fluid out. Truck shifted great on the test drive. Time will tell if this was the right move or not on this tranny....
