Originally Posted By: Vikas
... when you write similar construct, you write it so that there should be no question about misinterpretation.
Originally Posted By: Hokiefyd
Obviously, the best lesson from this is to be as explicit as possible. If more brackets were used, there would be no room for question here.
I agree with both. When I write a fraction less than 1, I always include a zero. Rather then write .7, I write 0.7 so that if the printer/copier did not show the dot/point clearly everybody would recognize 07 as 0.7 as oppose to 7 if the dot is missing in the ".7".
