2020 Ford F350 7.3L Gas
Truck is under warranty, repairs done at dealer.
Some history:
May 2023, 86,000 km / 3200hrs, drain and fill cooling system with OEM coolant/distilled water(Done by me)
Jan 9 2024, 108,000 km / 3850hrs Heater Core plugged, replaced by dealer.
May 29 2024, 119,775 km / 4180hrs Heater Core plugged, replaced by dealer, removed thermostat and flushed block, removed rad and flushed. Filled with new coolant.
June 2 2024, 119,900 km / 4182hrs Heater Core appears to be plugged again, lost heat on drivers side first, now little heat at all even from passenger side.
I've never seen or heard of this before, heater core becoming plugged almost immediately after a complete flush.
I would like to install a filter before the inlet on the heater hose to prevent this as it's getting old fast but have warranty concerns. If I did go the filter route does anyone have a suggestion as to what a good filter/housing setup would be?
Any ideas on what is causing this?
I asked them to cut the core open last time so we could see what is plugging them but they declined.
Some history:
