I built a new 385ci SBC for my Challenger over the winter. I'm currently breaking it in with Castrol GTX 10W-30 for a few hours. I'm looking for a good oil I can find locally that will be the best for this motor. I'm debating between Mobil Delvac 1300S 15W-40 or Mobil 1 10W-30HM mixed with M1 15W-50 Syn to make a nice 40W with a strong additive package. I've used the 1300S in my last two motors with great results. Both were 375-425hp SBC's. Upon teardown the internals looked really good. Very visible crosshatching, minor skirt wear, no bore polishing and great compression and leakdown numbers. The 360ci had 360hrs and the 355 had 136 hrs.
I change the oil religiously @ 25-30hr intervals. I mainly cruise 2500-3500rpms most of the time but race alot also with extended WOT runs at 5700-6000rpms. I have a large oil cooler and temps never rise much above 240*. Total oil capacity is a little under 8qts.
Videos of my Challenger
http://www.youtube.com/watch?v=ORkMT3JMWu8
http://www.youtube.com/watch?v=0HW3bFdTj88
http://www.youtube.com/watch?v=vuL_dEX0SoM
Engine Specs....
Ring Gap Top .022", Bottom .020" Mains .0015 Rod .0015
010 4 bolt SBC, bored .040", 0 decked, line honed,
ESP 4340 3.750 crank, ESP 6" 7/16" H beams, Mahle forged FT's 5cc, C77H bearings, Hines Balanced
Melling Racing #10555 oil pump, Hamburgers 7qt marine pan, full length windage tray.
FluiDamper harmonic balancer,
AFR 190cc heads, 73cc, further ported by Carl McQuillen Racing Engines, Isky 6105 dual valvesprings,
Marine Kinetics "RMbuilder" custom Hyd Roller 234/240 .580/.568 112+4
Morel Retrofit Hyd Roller lifters
Smith Bros .083" wall pushrods
Edelbrock RPM Air Gap port matched to AFR port
Holley HP 750 DP
Lunati Voodoo Widebody 1.5 roller rockers
GLM aluminum manifolds
FastGlass Stainless 22" long dry risers
Full MSD ignition setup, coil, wires, dist, 6AL,
10.07-1 SCR
Engine Specs....
Holley HP 750 DP
10.07-1 SCR
