300ZX oil change question
I need to change the oil this weekend. It holds 4.5 quarts. I have 4 quarts of Pennzoil Platinum 10W30 left. I have some leftovers laying around......half quart of Pennzoil Platinum 5W20, about a quart of Pennzoil High Mileage (conventional) 10W40,and a half quart of Pennzoil Conventional 10w40. Which oil would you use for that "half quart"?
These cars are not supposed to use anything "thinner" than 10W30 per Nissan fsm. Would a half quart of 5W20 be the least bit harmful?
Originally Posted By: SilverFusion2010
Add either of the half quarts. I'd use the 5w20 now and keep the 10w40 for top off
That's what I'm thinking too,to keep it all Pennzoil Platinum in the engine.
Originally Posted By: Linctex
I'll echo that - use that last bit of Pennzoil Platinum 5W-20
I disagree. That V-6 motor likes a diet of 5w30. I would not use the 20. BTW I had a 1990 300ZX.
Save Pennzoil Platinum 5w20 to top off honda.
Use Pennzoil Conventional 10w40 for zx.
Or just flip coins.
Hot summer in Texas? I'd go up a notch to the 10w-40's for the extra 1/2 quart. I'd save the 5w-20 for a "winter" oil change.
More than not, the Motor will like the 20 grade "additive" in there.
I think my Nissan Rogue might have a higher specific output than your Z - but I havent the calculus at hand ....
It runs MORE happily 4.5 qt 5w30 and 1/2 qt 5w20. engine loves it and you will still be a 30 grade.
Or just flip coins.
+1
