Hey guys I circulated some forums but no one seemed to definitively know; I've seen plenty of theory, but I have questions I'd really like to get to the bottom of. The 2 main questions here I have are which oil should I use for such a high mileage car for my engine and manual transmission, info below.
I have a 300k Civic DX and this will be the first oil change in my ownership, the previous owner said he used conventional oil. I live in Southern CA and in summer it can reach mid 90's and as low as 45 in winter in the early am, both numbers in Fahrenheit. The car has a minor oil leak but I didn't notice a change on the dipstick reading after 4+ months, so it's not bad. The engine has a very slight knock when it's below 70F at cold start for a few minutes. Vanishes once warm.
The manual recommends 10w30, but due to the minor leak I was wondering if I should go 10w40 and if I should use "high mileage" due to reading how high mileage oil swells the engine seals and can stop leaks.
The transmission is manual and also has 300k on it. The manual recommends 10w30 or 10w40 as long as it's API grade SF or SG engine oil. Wondering which I should go with? The previous owner used 10w40.
I'm not really looking to fix the knock or leak, with 300k I'm really just looking to ride out it's lifespan as long as I can, I am very easy on the car and it's running great.
