Here's why it aggravates me: At 30,000 miles on my 2011 Camaro, I wanted the pan dropped, the filter changed, and the fluid replaced. The dealership only wants to flush the fluid. I shouldn't have to argue with them about the filter 'not needing to be changed at 30K". I want it done. It's my car. Why argue with a customer over requested maintenance on a warrantied car? (I got this same runaround on my '05 Sport Trac, so I took it to Kwik Kar.)
Firestone agreed to do the whole job. I provided the filter, gasket, and fluid.
Without a dipstick, how do you check anyone's work? I simply wanted to know if Firestone under-filled it or over-filled it. I'd want to do the same thing if the dealership had done the job. This shouldn't require crawling under a hot car and unscrewing a 'check plug' in the pan to see if any fluid runs out (or doesn't run out) when at normal operating temperature. This is a clear attempt at making something a big PITA so that you feel forced to take it to the dealer. Well, guess what GM. Rather than knuckling under to that type of b.s., I just drove it, and prayed.
