My Father asked me to take a look at his McCulloch strimmer as it hadn't been used since last summer and wouldn't run.
I changed out the fuel/oil mix for fresh and it started right away and seemingly runs well with plenty of power. However, as soon as you hit full throttle and not a millimetre sooner, the engine bogs down and if left at full throttle for more than a second or two it will bog down to the point it cuts out.
I thought the high end fuelling was out but there is no adjustment screws on the carburettor at all? Is this normal? After this I went to look at the carb on my unbranded strimmer and also noticed there's no fuel adjustment screws. The only screw is for idle.
So anyone have any ideas what to do here? Like I said, other than at WOT, it runs perfectly. I'm not sure what to do next.
