24 GMC Sierra 1500 Diff fluid Change Observations.
USA
Decided to change the front diff fluid on my GM SU5 axle 2024 Sierra 1500 with 13k miles. Replaced with Amsoil 75w-90. Not a fan of more fuel efficient GM 75w-85. Anyways I noted the fluid looked fresh but was very cloudy. You can see some white colored ripples on the pan when it dripped. I use my 4WD or Auto mode (basically AWD light 4WD fuel efficient) when it rains hard or snow fall in Minnesota winters. Should this fluid with condensation be normal due to my location. Sounds like that combined with low usage seems to give it less chance to heat up and burn moisture out like the rear fluid. Recently did rear diff and it was not like this. Pretty clean honey color. I think this diff was under filled too from factory because the fill plug magnet was clean. Only the cover glued on rubber magnet has some material.
I changed my old 2011’s front diff one day in like 2019-2020. It came out looking like chocolate milk. At least yours is still amber’ish kind of colored lol
This is off GM website Front diff. lubricant-
  • ACDelco Dexron 75W-85 Low Viscosity Gear Oil is a newer SAE technology that helps reduce operating temperature, improve fuel economy, and improve thermal stability. The low viscosity formula is favorable for high speed, low loaded gears with a good tooth surface finish. ACDelco Dexron Low Viscosity 75W-85 Gear Oil has been formulated to meet your expectations for durability and longevity.I would rather have gear oil coming out looking like that than some of the black and dark grey lube I have drained before! I suspect that color is because it is a special GM formula for front axels.
The fluid almost looks like moisture holding. Not sure what virgin looks like though. Kinda ugly.
Just good that you changed. I always change my driveline fluids early and again. Then I can go a good while.
Based on a few YouTube videos doing the same service using oem AC Delco fluid the new oil look clear like any other brand. I’ll have to think about when the next fluid change will be. Would be great if PML decides to release their prototype diff cover that has a drain. Most likely I’ll do 3 years 30-40k miles for next service.
Update:
Whenever I’ve used 4WD or Auto I noticed the front axle will have a humming/ slight gear white. Nothing be concerned about but you could tell it was engaged. Since I switched to Amsoil Severe Gear yesterday on my commute all of that front axle humming or gear whine is gone when engaged.
