Well, I guess this explains the odd electrical issues recently.....
If I had a lift like you - I’d snatch that lawn mower battery from under the plastic fender - tape off the leads. I did the N1>N2 with starter cable - but they are side by side and a 2 hole copper bar would be cleaner …Dang I better go check the one on my Gladiator
Never received any warning....just stop/start went inop.
That is a good idea. I actually have disabled the auto stop so don't need the battery and its future problems anyways! I will look into doing that at the next oil change as the original lawn mower batteryIf I had a lift like you - I’d snatch that lawn mower battery from under the plastic fender - tape off the leads. I did the N1>N2 with starter cable - but they are side by side and a 2 hole copper bar would be cleaner …
That sounds excruciating.Don't get me going on stop/start w/ a manual transmission.....
What’s the latest? - if you see my post - once you remove the Aux14 and tape up the leads - run a short starter cable N1>N2 and a new AGM H7 will handle it all … it’s been 2 years with zero issues for me …A buddy of mine just lost both batteries. They live in parallel so if one starts to go it drags the other down with it. He did the mod to replace the primary and disable the aux.
The gladiator itself runs fine but the vehicle electrics don’t. The radio in particular seems impacted. He leaves AS/S enabled and just drives it. Based on this, he plans to go back and add the aux back in. The vehicle did give him dashboard warnings for months that the aux battery was weak and AS/S was disabled. Had he replaced the Aux battery, it probably would not have drained the starter battery.
It looks like when the engine shuts off, a relay separates vehicle systems to the aux battery so the voltage doesn’t dip while it starts off the main. All things considered, that’s pretty cool. I think they could have managed better by also separating them during power off.
Good question - I haven’t asked. I *think* he went back and installed the aux battery.What’s the latest? - if you see my post - once you remove the Aux14 and tape up the leads - run a short starter cable N1>N2 and a new AGM H7 will handle it all … it’s been 2 years with zero issues for me …
To follow up, this is the one I chose. Very, very well made, OEM appearance, and simple install. Thx!That sounds excruciating.
I've heard this is one of the better ones, but haven't done all my research
https://www.smartstopstart.com/jeep-dodge-chrysler-products.html
