CleanSump
Site Donor 2026
I want to believe, therefore it is. "All" is a very finite word.
It's the lack of or a reduced level of certain friction modifiers that makes the JASO rated oils meet the SAE #2 clutch test friction specifications defined in JASO T903. What else in an oil's formulation would affect the friction level to meet the JASO friction specs if it's not connected to friction modifiers? Sidenote - ATFs also need to meet a defined oil friction level to work properly in an automatic transmission, another type of wet clutch.Moly, zinc and boron have no negative press, per se, with respect to a wet clutch to my knowledge unless there's something I missed on this forum. Based on my experience there are no issues, not just floating out food for thought.
Manufacturers would not put elements in their oil above and beyond what is considered traditional amounts in order to become energy conserving, if the oil is disqualified from energy and conserving from the get-go because of viscosity. That's a business fact. Zinc is lower, moly and boron are higher and were not present at all when friction modifying came to be a buzzword, decades ago in the proportions they are now. Friction modifying is a bunch of bull crap yet provides very good discussion despite never having been identified. I would venture to guess the only thing friction modifying is the actual viscosity. There's no part of the additive package that contributes to that unless someone can show otherwise.
Zinc moly, boron are typical friction reducers/modifiers. Oils above 10W-30 or oils below 10w30 all have them. Agree.It's the lack of or a reduced level of certain friction modifiers that makes the JASO rated oils meet the SAE #2 clutch test friction specifications defined in JASO T903. What else in an oil's formulation would affect the friction level to meet the JASO friction specs if it's not connected to friction modifiers? Sidenote - ATFs also need to meet a defined oil friction level to work properly in an automatic transmission, another type of wet clutch.
Oils above xW-30 aren't formulated to be "Energy Conserving", but that doesn't mean they are void of friction modifiers. There's more to friction than just the actual shearing of the oil film as a function of the oil viscosity. There are AF/AW additives to help reduce wear for parts in the boundry and mixed lubrication regimes. Even with a xW-40 or xW-50 there are parts rubbing together that AF/AW additives help to reduce friction and wear.
If the type and level of friction modifiers didn't matter, then every oil on the market would meet JASO (and JASO probably wouldn't even exist in the firstplace), and all the motor oil manufacturers would put that it "Meets JASO MA/MA1/MA2" on the oil bottles to sell more oil. Will a non-JASO rated oil work? Sure it can, and a lot of that has to do with the specific design and clamping force of each specific clutch (number and size of plates and the pressure plate/springs clamping force) which means there could be a lot of performance variation. Doesn't mean any oil will always perform well in a wet clutch. A weak or badly designed clutch will obviously be more sensitive to the oil's friction level.
Like said earlier, if all oils above xW-30 could meet the JASO friction spec requirements then all an oil company would need to do is have the friction specs tested and then put "Meets JASO MA/MA1/MA2" on the bottle or jug. They wouldn't even have to send the test data proof and register it formally with JASO (that's what Shell does with Rotella), which isn't that hard to do once the testing has been done. So the formulation has to matter in terms of oil friction performance. The final formulation is probably a more comple synergy between all the additives, and the base oil could also be a factor. There have certainly been some wet clutch bikes that don't like non-JASO rated oil. Each bike is its own "test bed" when using non-JASO rated oil - most may seem to work fine , but not ever bike will.Zinc moly, boron are typical friction reducers/modifiers. Oils above 10W-30 or oils below 10w30 all have them. Agree.
Recent UOA of Pennzoil Ultra Platinum 5w20 has 70 ppm moly, 88 boron and 659 zinc. Most definitely an energy conserving oil and NOT JASO. Castrol 5w30 Edge with 58 moly, boron 11, zinc 842. Same as above, energy conserving yet not JASO. Kirkland 0w20 72 moly, 0 boron, 795 zinc. Energy Conserving, not JASO. Honda 0w20 65 ppm moly, 52 ppm boron, 906 ppm zinc. Energy conserving, not JASO.
Bel-Ray 20w50 semi-syn has 153 ppm moly, 34 boron and 894 zinc. Eliminated by viscosity alone from energy conserving, yet JASO MA2 rating. Honda HPS 10w30, 89 ppm moly, 49 ppm boron and 1008 zinc. Meets JASO MA2. Redline 20w50 from my analysis 290 ppm moly, 45 boron and 1672 zinc, JASO MA2. Amsoil 20w50 ftom my analysis 108 moly, boron 124, zinc 1209. JASO MA2. Valvilone 20w50 syn, 24 ppm moly, 272 ppm boron, 1070 ppm zinc. Amsoil 10w40 metric moly 68, 195 boron, zinc 1224. Not energy conserving yet JASO MA2.
That cross section of analysis can done over and over with multiple oils that are energy conserving versus JASO approved. Energy Conserving is not moly, boron or zinc dependant by themselves or in combo. The thing I see is viscosity may be a common thread that can connect this, or other difference that has not been defined as a specific additive.
Yes, from what digging into it any viscosity above a xW-30 is automatically disqualified from getting the API "Energy Conserving" approval. The HTHS viscosity which affects fuel economy is too high for construction, regardless if the formulation has enough friction modifiers to make it perform like a xW-30 with respect to fuel economy.I may have miss understood, it was said anything above 10w30 is disqualified regardless because of the viscosity lowering efficiency and no amount of friction modifiers can overcome that. And what I see shows companies are not trying to overcome it with friction modifiers. Maybe I've interpreted that wrong?
The way I look at it is JASO wouldn't ever have materialize if automotive motor oil's friction level at some point didn't matter to motorcyle wet clutch operation. I'm not going to use my bikes as a wet clutch test bed, that testing has already been done by people using the SAE #2 friction test procedure specifications in order to lable their oil as meeting the JASO friction specs. The formulation also has to meet some other requirements too, but the 3 different types of friction specs in JASO T903 are the main focus. Yep, good dialogue.I appreciate the good dialogue, I'm thinking the jury is out with all of this in my opinion. Or the jury is doing just fine and the additives or lack thereof are a whole lot to do about nothing.
I was editing my post as you were posting so I put some more thoughts after you had quoted. However, I appreciate the dialogue like I said. This is good discussion in my opinion.
Oil formulators were working on making motor oils "Energy Conserving" way before JASO came along in 1998. And the actual "star burst" logo was put on oil bottles many years before JASO ever came along. I don't think JASO waas some "wizard behind the curtain" trying to scam the oil industry and motorcycle owners in some way, there was a legitimate reason it was formed based on how motorcyles with a wet clutch were responding to automotive motor oils in the 1990s Like said, if every oil would work great in a wet clutch, then any oil maker could slap on "Meets JASO MA/MA1/MA2" on the bottle and call it a day. Or if someone uses their bike as an SAE #2 oil friction "test bed", then they could write "Meets JASO MA/MA1/MA2" on the bottle with a Sharpie pen if the clutch didn't seem to slip.The litmus test would be was there an increase in clutch slippage that lead to JASO being introduced in 1998 after the energy conserving label in 1997?
JASO was a quick turn and burn so to speak, as it happened within the year after energy conserving was added to the back of oil bottles. I don't read about "the year energy conserving oils killed the motorcycle clutch", per se. I can't find a rash of clutch slippage at that point in time when I search for it.
Seems a lot like the "wizard behind the curtain" and a solution in search of a problem that was marketed as the sky falling and has been with the oil world ever since.
Like I've said, friction modifiers have not been identified other than the traditional ones that are discussed day in and day out. The examples I compared a few posts back are no different in quantities between energy conserving and JASO oils. Only difference for practical purposes is the oil grade.
I choose to use motorcycle oils from the fact they hold up very well in a shared sump such as Mobil 1 4T 10w40, 20w50 VTwin, etc.
what oil?I'm in asia so unfortunately no. I'd want to stick to manual, but with the weird pricing here I'm just wondering because it seems like a joke that thicker oil with inferior spec priced the same as the higher spec thinner oil. If sticking to 20w-50 is the best choice I'd stick with it then, hope others can chime in.
