Here's a technical run-down of the 2013-2016 CX-5 Skyactiv engine with what Mazda is calling "Accelerated Warm-up System or AWS"..
My post was not about the warming up of the car but rather the 5w30 usage in winter. And yes it does make an exhaust flatulent sound when the AWS system is running.
Link is below of the complete bulletin..
Couple of excerpts from the technical bulletin:
"DESCRIPTION: Some customers may complain about an unusual noise coming from the engine compartment for about 20 seconds after a cold engine start. This noise is a normal engine operation for improved exhaust gas emissions. The noise does not indicate a malfunction.
ACCELERATED WARM-UP SYSTEM (AWS): All SKYACTIV-G engines adopt AWS to reduce exhaust gas emissions immediately after a cold engine start. AWS increases the engine idling speed and retards the ignition timing for about 20 seconds after the cold engine start to quickly warm up the catalytic converter. The customer may identify the engine sound during the AWS operation as a unusual noise."
And as I was saying, running rich usually is more fuel but to argue it is pure semantics, either way it does use fuel to warm up, per the bulletin, quoting:
"AWS burns fuel inside the exhaust manifold (A) to quickly warm up the catalytic convertor. The customer may identify the burning sound as an unusual noise"
EDIT: Link attached:
https://static.nhtsa.gov/odi/tsbs/2020/MC-10179079-0001.pdf
