2022 Honda civic spark plugs
NGK 95112 ILZKAR8H8S Laser Iridium Spark Plug​
NGK's website says these are the proper plugs for a non Si Civic 1.5T engine.
Not per my search (see below). There is a note that says the OE plug is a "high ignitability" spark plug. Not sure what that means, but this 92411 plug is ~$25 each and is only warranted for 2 months!
they went to the trash i didn't look at the parts number on oems but ngk's website listed the same part number that i put in
You still have not clearly identified the part number on the new NGK spark plugs that you put in from NAPA. Is it 92411 (AKA, DILKAR8P8SY) or something else? If it is 92411, the NAPA sourced plugs are possibly counterfeit, not genuine NGK.
Bring the old ones back to Napa, they should give you your money back since they sold you the wrong ones.
In any event, you should at least attempt to complain to NAPA. Perhaps you'll get a refund.
I ALWAYS replace with the original factory spec spark plug.
Nowadays I think most OEM plugs are iridium and are better quality than the aftermarket choices. It’s definitely the case with both of my cars, I would never run anything but OEM in them.
It seems that Honda changed the spark plug model when they released the 11th gen Civic. 10th gen 1.5T engines used the 95112, but 11th gen switched to 92411. As far as I know, the engines are the same. Apparently, there must be some subtle changes, not readily apparent. And everyone is free to do as they want, but for me, I'm not going to buy plugs from a dealer unless there is no other choice.
