2019 Ford truck transmission change
Hello friends, I’m doing a transmission fluid change in a 2019 F150 XL Ford truck, it has the 3.3 L
What fluid would you recommend what brand, thank you
Motorcraft Mercon ULV
Ford part number: XT-12-QULV
The 10R80 requires Mercon ULV only. Do not substitute Mercon LV
Alternative is Valvoline ULV ATF
A lot is going to depend on what transmission is in that truck. It looks like you could still get the 6R80 with the 3.3L which would take Mercon LV. If it has the 10 speed it would take Mercon ULV.
This?
I think his truck may have the 6 speed, not the 10 speed automatic, but Ford still lists the Mercon ULV fluid, not the LV, for it in the service info.
Amsoil ATL is my pick. Not cheap, but I’m a real believer in Amsoil’s ATF and gear oils. Very good products and experience with them.
What he said. Verify which trans you have and LV if it is a 6 speed or ULV if it is a 10 speed. You won't go wrong following that.
LV is far easier and cheaper to find than ULV as well. Lots more choice.
Here's what parts.ford.com says for a 2019 F150 gas truck with the 3.3l. It appears they switched them from LV to ULV starting in 2018.
https://parts.ford.com/shop/en/us/f...matic-transmission-fluid-oil-p-xt12qulv?pdp=y
https://parts.ford.com/shop/en/us/fluids-chemicals-and-lubricants/automatic-transmission-fluids/automatic-transmission-fluid-oil-p-xt12qulv?pd
That website is misleading. The 6R80 takes LV, period. If it’s the 10R80, then you would use the ULV. 2019 trucks had more than one trans option.
It shows that you have the 6r80 6 speed transmission, which is one of Ford's better ones. Motorcraft says use Mercon LV fluid in it, and that's what all the earlier years used, so that's what I would use in it.
Did I get the right transmission fluid? The pictures are going sideways for some reason, do I need to go by Mercon LV
I went back and returned it. It’s less than a mile. This is what I got it Mecron 5LV
