Just sold our old minivan and purchased a new forester. The minivan spec'd 5w30 (which I have 15 quarts leftover, probably should have given it to they guy who bought the van) The Forester requires (or recommends) 0w-20 unless
you use in hot weather (I'm in So Cal)
several of you might remember this confusing / contradicting info in the owners manual
"0W-20 synthetic oil is the required oil for optimum engine performance and protection. Engine oil viscosity (thickness) affects fuel economy. Oils of lower viscosity provide better fuel economy. However, in hot weather, oil of higher viscosity is required."
Bottom line, can I use 5w30 or should I swap with someone on BITOG
for 0w-20?
